Hi Guys.My First post.I have this go cart/bar stool racer I built about 10 yrs ago and I want to try and scratch build it.I just started scratch building about 3 weeks ago and have 3 cars done so far.So i,m thinking about building 2 versions and making them wheel standers.I,m thinking of mounting the motor some- what vertical to simulate an engine cylinder and make the front lift easier.I want to do one with 2 motors to simulate a V twin. I did a quick drawing to help explain what I'm trying to do.I realize I need to get two matching motors.So here is what I,m hoping someone can help with,for the twin version I am hoping there are 2 different motor brackets that one will fit inside the other.This would be easier than trying to fit 2 of the same size brackets together. I have searched for dimensions with no luck.looking at Slotcar corners site they show 6 different brackets under 1/24 parts by type.I am wondering if JK F1/Indy Motor Bracket would fit inside the JK D3 Motor Bracket. Thankx-Dan
New project
I use the JK F1 motor bracket a lot for 1/24 and 1/32 scratch builds. It measures 3/4" wide.
Never used the JK D3 bracket but likely wider.
Have you checked out PCH Parts Express at www.e-slotcar.com for their parts? Great selection for the scratch builder. A recommendation of chrisguyw, builder of some exquisite chassis and slot cars.
Very cool project and results. You have excellent scratch building skills.
However, as someone with a lot of experience doing head injury research I seriously suggest you NEVER ride the full sized bar stool cart without a certified helmet and/or roll cage. Even good helmets can't prevent concussions, but they can typically prevent cracked skulls. When head makes contact with pavement, head loses every time. Be careful.
