I'm having a problem straightening a Thunderslot Lola chassis. The chassis is the black one that comes with comes stock with the car.
It had a slight bend in it - along the long axis, so I used the Slot.It boiling water/oven straightening process. The result, more bend than before. So, I re-straightened it again last night using the same process. This morning it's worse than after the first straightening and I suspect that I'll have to throw it away. I've successfully straightened a lot of chassis using this process, so the problem is not that I'm doing the process wrong.
Has anyone else had this kind of problem trying to straighten a Thunderslot chassis? Is the Slot.It heat straightening process taboo for this brand?
