I’ve gotten so use to Slot-it and Frankenslot no trigger tension, was wondering if there’s a different spring available? I’ve oiled the bearings and it helped some but still stiff.
Difalco Spring Tension
If I recall correctly the Parma Economy springs have less tension than the Turbo/Sebring springs. I prefer more tension, to me the spring in the latest OS3 All Pro Elite is much too light, so I switched to a Turbo spring that I had hanging around. If you can't find the correct spring you might be able to re-locate the mounting point, so it is a little closer to the trigger.
I just checked the Parma/PSE site and the springs are listed under the trigger parts.
You can just go to your local hardware store. They have all the drawers with different nut and bolts. They usually have different springs with different tension. I am just the opposite and like a stiffer spring.
Here’s the reply from Jim. “If you have a controller that was new in the last couple years it already has a very light spring on it. If it is over a couple years old then my new springs have a lighter tension. “ My HD30 is a few years older , with the stiffer spring. Ordered a spring from Jim. Thanks for the repliesTony
Pass Christian, MS
