This subject was touched upon some time ago, and I can't remember what the exact Topic was. Somehow, I'm not finding it. Anyway, what I need to know is : Can JK motor brackets JKC86 and JKC82 (C82 is narrow 3/4" Indy/F1, which requires offset crown gear) be modified with a reamer, to work with a 1/8 Axle and it's big crown gear ?? I'm sure I've seen a 1/4" Bushing with a 1/8 axle hole, on Slot Car Corner's site. The big crown gear needed and the bigger-diameter pinion that mates, are 48 pitch. I would normally use the LVJ chassis for the projects I have in mind, but sometimes I need a narrower total-width rear end, when you factor in the ProTrack wheel/tires combination. It may all be just too much trouble, I suspect, but if it's possible to use the JK brackets with the ProTrack stuff, I'd like to have that knowledge !! I guess I'm really speaking about that narrow 3/4'" bracket, as the LVJ motor box is similar width, to C86, maybe actually a slight bit narrower. It just can be difficult finding bodies wide enough to tuck in the LVJ/ProTrack combination wheels/tires. And I have a couple of reasons for wanting to use the ProTrack wheels/tires. Thanks in advance, for any help.
Modifying JK Brackets ?
Hello 6666hotrod,........No need to ream out your bracket !!,............you can buy 1/8 x 3/16 single flanged oilites that will slip right in.
You can find these at PCH Slot Parts, Professor Motor, MidAmerica, Slot Car Corner (and other good slot shops)
As far as concerns about the "offset" in the bracket , you would be wise to use an "angled" 48P pinion, made by ARP, coupled with an original 48P "Parma" or "MidAmercia" (Parma repro Crowns). The Parma/MidAmerica repro Crowns will mesh perfectly with the ARP pinion,.......this is the go to gear set-up used by all the top racers using the JK/RGEO offset motor brackets.
You will find the 48P "ARP" pinions at PCHSlot parts, while they are a bit more expensive, they are EDM cut stainless steel, and are as good as they get .
While I am sure you already know this,.....you should align your bushings (axle installed) and secure them by either soldering or using "Red" loctite.
PS The pinions are installed with the smaller "angled" diameter facing the rear axle.
Here is a pic. of the "ARP" angled pinion.
- Likes 3
We have the bushings you're looking for in stock. Here is a link:
1/8" Axle Oilite for 3/16" Hole
We also have ARP Angled solder on pinions like Chris mentions above. Here is a link to the 9T version.
ARP 9T 48P Angled Solder-on Pinion
And finally, we have the complete line of Mid-America Parma Repo Crowns. Here is the link.
- Likes 3
