Near the end of July, I posted "A Straight Answer About Which Hand Controller". 'Boy, I am at the same time, both Embarrassed, and TOTALLY THRILLED to report that I had A Lightbulb Moment, this afternoon, THAT SOLVED THAT PROBLEM (problem being that this $80-plus slot car drove like an on-off switch/all-or-nothing, and I needed to know what hand controller would control it !) I can't believe I didn't think of this earlier, like I thought of today : TAKE THE MAGNET OUT, just to see what happens !!! So I'm expecting it to probably still be something of an on-off switch, and not handle at all, now. I WAS STUNNED when it ran and lapped like one of my better scratch builds, which is sayin' something, as two of my scratch builds hold my little layout's ultimate non-magnet Lap Record, which includes several badd Slot.it cars without magnets featuring silicone tires !! Those scratch builds feature Paul Gage firm urethane tires. So, I literally went from being totally frustrated with this beautifully-made NSR Formula 86/89 car, to being totally under it's spell : I Couldn't Stop Running Laps !! Within a few laps, it had tied that Lap Record back to back to back, EASILY !! These are the best Rubber tires I have ever seen, by the way. I can't understand why NSR would even put a darned traction-magnet in this sweet chassis. It runs and laps as well as my RevoSlot Ferrari 333SP, which came without a traction-magnet (well one comes in the box, if you want to install it, but why would you??). If I decide to put Paul Gage urethane tires on it, it'll be A Monster, and likely set a new Lap Record for my track! That magnet had the car, Totally Bogged Down, to the point it would only run at near full throttle ! Now it runs, all the way through the controller's range, beautifully. And I was considering changing this super-badd motor, or even spending unnecessary money on an expensive controller. As they say : All's well, that ends well.
The Hand Controller/NSR Question ANSWERED !!
If this is your first NSR car, then you don't know what traction is until you hit those tires with some lighter fluid. (on a bit of rag or paper towel, and applied to spinning tires.)
Did you mention in that previous thread that you were running a car with magnets still in it? I don't remember if you did, but it's quite common for a car to be like that when it has a strong motor and a strong magnet. Top it off with the relatively soft/flexible chassis and pod of most NSR cars, and it's possible the magnet was causing the pod to actually drag on the track.
Originally posted by 6666hotrod View PostThese are the best Rubber tires I have ever seen, by the way. I can't understand why NSR would even put a darned traction-magnet in this sweet chassis. If I decide to put Paul Gage urethane tires on it, it'll be A Monster, and likely set a new Lap Record for my track!
