I'm an old guy so bear with me. I got into slot cars in the '60s and worked at a local raceway. I eventually scratch built my own cars and rewired lots of motors. Then life got in the way (you know, a job, marriage, kids all that stuff). So now that I'm an old retired (sort of) guy I've decided to get back into it. Obviously lot of things have changed. I started with what I knew and collected a bunch of Scalextric classic track and cars. They came with controllers and other accessories. I've now started building tables to set the track up on. The track is going to be set up in a garage so I have to be able to break it down to put the motorcycle back in, but I wanted to make it as large as possible. So I've drawn up a layout (using AnyRail6) using three 4' x 8' tables (well technically a 4' x 8', a 4' x 10' and a 4' x 6') in a U shape with fold down legs. I plan on using power taps to keep the power up around the track. Where the tables are joined I'll probably use 4 prong connectors for the power.
I've been looking at power supply options and decided I need some help sorting it all out. I understand that I want a regulated power supply but I'm not sure what kind of output I should go with. I've been looking at 30 volt 10 amp units. Am I in the right ball park? I've downloaded a wiring diagram manual from slotcarcorner.com so I think I've got that part covered. I also see that the controllers are much more than what I used to have back then (I think it was a Cox controller with a plunger). Now I see there are all kinds of dials to control braking and sensitivity. I also see that you can spend $300 plus (which I do not plan on doing).
Any help regarding power supplies and controllers would be greatly appreciated. For now I'm probably going to use the stock Scalextric cars but I'm sure I'll eventually start back making my own.
Thanks,
Joe
Thanks,
Joe
