7mm 11t metal pinion
  • 7mm 11t metal pinion
    so ive been looking all over for a 7mm 11t METAL pinion,cant find one. do these even exist? looking to replace the plastic ones from thunderslot cars.thanks,bill
    bill ,framingham ma
    NSR 6911 is brass and 6.75 mm should be just fine.
    Mike
      thanks mike
      bill ,framingham ma
        An NSR 6911 pinion (6.75mm) with a stock Thunderslot Spur.......no issues,.......you will need to carefully position the pinion on the motor shaft, and, the the Spur laterally on the axle (use .005 spacers for the spur) to achieve just a touch of lash.
        The mild angle of the motor in the Tslot motor pod, does allow for some very minor lash adjustment by moving the Spur laterally on the axle.
        PS metal 11T 7mm. pinions are unfortunately not available.
        Click image for larger version  Name:	DSCN4717.jpg Views:	1 Size:	244.6 KB ID:	164052
          Great info ,thanks
          bill ,framingham ma
