hello
A question to all who use aftermarket urethane tires, Or makes them. Do the tires you use degrade ? wear out? And life span? 1000 laps? give or take.
As you can see in the photo there is quite a lot of "marbles" or "klag " as the brits say, on this car . A would guess that's about 600 laps on those tires.
Now these are tires i make myself using a urethane rubber.A 2 part mix . I get it at Smooth-on. Its is available in different hardness's I use a 30 grade .
which is towards the softer end. Do you lose grip if you go with a harder compound?
We run on a digital wood track ,so magnets are not a factor here .
Any thoughts anyone?
thanks
john
thanks
john
