Looking for tire and tuning Suggestions? The car runs good out of the Box but I know there's more potential.
Policar BRZ
I think you will need to replace the rear wheels, tires, and crown gear. It has plastic wheels and knurled axles. You have to pull the wheels and crown gear in order to remove the axles to true the tires.
If it was my car, I would convert the guide assembly to a Slotting deep wood guide, install a decent motor with a brass pinion, new rear axle with slot.it crown gear, CB design wheels, PG urethane or Quick slick silicone tires and some lead in the sides of frame next to the motor. That would about max out the potential short of doing some major work to lower it.Last edited by Bal r 14; March 19, 2022, 10:06 PM.
