Done maybe 7 to 8 searches, and just can not get a straight answer, to a simple and direct question : Will painting Piano Wire, after it's been soldered, Prevent It From Rusting ?? (The reason I won't use it for scratchbuilding, is because it sounds like a Pain, after your 'build ! If simply Painting It, prevents this, I could really use it. Thanks, in advance, guys and gals !
Piano Wire
If piano wire is cleaned after soldering, it will not rust.........I have plenty of 30+ year old piano wire chassis with no rust.
If you choose to paint the chassis, that is fine, but again, it must be fully cleaned/primed before painting.
I do not have any handy pics. of really old chassis, but, this one was built close to 15yrs. ago
- 4 likes
Chrisguyw is right - I think the acid and flux is the enemy so a clean up afterward is the way to go.
They do sell stainless steel music wire as well, so something else to play with.Last edited by Vintage 1/24; February 12, 2022, 07:06 PM.
- 1 like
If you're cleaning joints made using an acid flux, it's a good idea to wash them down with a mixture of baking soda & tap water. The baking soda neutralizes the acid. When I build, I keep a mixture handy to use continuously. I don't paint chassis because when you have to resolder a painted joint, it makes a mess. I had much rather just use metal polish on an old toothbrush for a shine.
- 2 likes
Just a tid bit of humor for the morning coffee! Have you ever walked in to a hobby store and ask for piano wire? And get a blank stare???? Well I just moved to a town in New Jersey and went to my LHS yes a local hobby shop and asked where the piano wire was and got the dreaded blank stare... Explained to him what I needed and he with the biggest smile ever said OH MUSIC WIRE that's over here!
Happy Tuesday!
Marty
