I have two set of switches one set for switching from a road course to an oval course and another set for lane switching. Question is: How do I use one power source 12V DC 2 amps to power the switches? The switches to change courses only need to be on for road and off for oval. The lane changers are all set and work fine. The issue is that I can't figure out how to run the wiring. When I turn of the switch the lane changers go off as well and I can't figure out the correct diagram to make this work.
Any help would be appreciated.
Thank you
Right now I have a separate power source for each and it works fine. Just wonder if I could use only one??
Thank you
