I've been truing the tires of my 1/32nd scale cars on a Professor Motor tire truing machine. A feature of that machine, and machines like it, is that you can mount the whole axle of a car on the machine and true both tires at once.
Problem is, those tires don't end up the same diameter. It is a common issue and the only fix I know of is to reverse the axle in the machine and run it again. With luck both tires will end up the same diameter.
But I don't know if that really works. What I need is a good way to precisely measure the diameters of those tires. A caliper is a great tool for doing such measurements, except that it does apply some compressive force to the tire, and tires are compressible. They are designed to be! So it is not at all easy to get precise and consistent diameter measurements that way.
An alternate method to measure tire diameters is with a tire gauge. That's a sheet of plastic with a number of holes in it of various sizes. You try to slip a tire through those holes, and find the smallest hole it will go through. In industry this is known as a Go/NoGo gauge. Works okay, but if you want to measure tire diameters to a thousandth of an inch you are going to need a lot of holes.
Now me, I'm not one to do anything in a conventional manner if I think I can come up with a better one. So I designed a tool to address that whole comprehensibility issue. The idea is to spread around the compression force enough that a calipers can be used to precisely and consistently measure tire diameters. And you know what? That tool works! I can get precise measurements consistent to +/-0.001 of an inch.
'Course it would be nice to get more precise measurements, but plus or minus a thou' is pretty good. Not too easy to beat that.
So here are some photos of my tool. How it works should be self-explanatory.
And just for giggles, here are the Mark 1, Mark 2 and Mark 3 that I 3D printed while evolving my design.
They all worked, but each iteration worked better.
So does reversing the axle in my tire truing machine produce tires with the same diameter? I haven't done that study just yet.
Stay tuned...
Stay tuned...
