Hello Slotcar afficionados, I wanted to buy a specific slotcar but its no longer available. Doing some research and I found that all the parts are available separately. The body, chassis, motor, running gear, wheels , tyres etc. The only thing that is assembled is the body which is painted and fully decalled. My question : Is it difficult to assemble all those parts without any prior experience nor diagram/instructions to follow. Maybe a video on youtube could give me a better idea about what to expect. Surely no engineering degree is needed ? LOL Any feedback would be appreciated.
Assembling a Slot car : Is it difficult?
Originally posted by VermillionRed View PostHello Slotcar afficionados, I wanted to buy a specific slotcar but its no longer available. Doing some research and I found that all the parts are available separately. The body, chassis, motor, running gear, wheels , tyres etc. The only thing that is assembled is the body which is painted and fully decalled. My question : Is it difficult to assemble all those parts without any prior experience nor diagram/instructions to follow. Maybe a video on youtube could give me a better idea about what to expect. Surely no engineering degree is needed ? LOL Any feedback would be appreciated.The Jester
Soxside (Chicago)
The basic answer to the original question is no, it's not hard to assemble a slot car. You can use an existing car as a guide to what goes where. You may need tools designed for small parts but they can be acquired easily. If soldering is needed you can even learn to do that with a little practice.
Once you reveal more about the type of car someone can offer explicit advice.
Originally posted by VermillionRed View PostThanks for all the advice . The car in question is a Porsche 962 IMSA made by BRM in scale 1/24.THE other Vancouver aka Vancouver Washington across the river from keep Portland weird....
They're not hard, and Alan out in Tacoma is plenty of help, good setup scoop archives over on SCI. I've bought or built the 9 or ten of em here amongst the rest in Group C....and the others..
Hopefully pictures will be around soon from the Toy Fair next week of the solid rumored new liveries and cars in class🤞
Edit: Though Alan is busy out there,...they used to build them for a small set fee, if you gave him the time to get to it, I would bet given a few weeks or so he might take it on...
but as said it's straightforward and not difficult
Cheers,
PaulLast edited by FC47; January 26, 2022, 11:57 PM.
132Slotcar still has kits on it’s website. A downright bargain considering some people are asking $500 for the same on the auction sight.
Get a body from him, if he can source, or another supplier and go for it!
I’m told the hardest job is setting up the gear mesh. I was told to set it tight and run in at low voltage using toothpaste on the teeth.
Impressive car, as are all of the 962s.Last edited by WB2; January 27, 2022, 04:55 AM.
Yep, some of what's left out there of the early generations has gotten nutty for money. Good point on toothpaste and gear lash, especially to compete the car. Racing results have had at times a well tuned inline beating the angles.. my angle 88C's are the fiercest of the bunch,
mark the crown with a sharpie dot for its tightest mesh, either config, set that point to almost no lash, bit of lube (paste-should you choose) run it some, check lash, repeat, (clean from paste).
Anglewinder -patiently shim the the 'dotted' gear/spur to meet the pinion with almost no lash, run it in, adjust to minimal lash.
The cars really perform well, and either configuration once in the sweet range the cars very noticeably come alive.
See if you want to have Alan outfit a build, I had one done early on, as his time reasonably permits.
He is certainly all about his cars.
Cheers,Last edited by FC47; January 27, 2022, 09:44 AM.
