Disassembly of Scalextric Dodge Charger Daytona
  • Disassembly of Scalextric Dodge Charger Daytona
    Hi All,
    I just received this car, and I was in the process of taking it apart, when I found that the front won't come loose. Not wanting to break anything, as this wasn't a cheap car, but what is the secret to taking the body off this car? Does the nose simply pop off? It looks like it might, but I don't want to break anything. I've removed all 6 screws, but the front is still held on with something.
    Thanks in advance
    Scott,
    The nose is glued on - you have to cut the chassis in order to open it up. If you want one of those to mess around with I will give you mine and you can see if you can get it to work for you and then give me what you think is fair.
    Peter
    PetesLightKits
      Thanks Peter, I think I'll just park it.
      I don't know how Scalextric could be so stupid in designing something like this. Obviously quality control isn't a high priority for them.
      Stay safe
        Holt crap, they didn't even attempt to make the nose fit flush with the body..
        Saginaw Valley Raceway
        • Wobble
          Wobble commented
          At the time I thought about getting one of these but that oversize nose put me off.
        I think I had mine apart many moons ago when I bought mine. Could be wrong. I will have to check mine after work.
          Well at least they're fit correctly.
          • Wobble
            Wobble commented
            Yes, I ended up getting one of these as well rather than the Scalex version.
          Ok. Well here you go. With some gentle persuasion I got it apart. There is a dab of glue at the front lower part of the fender that glue's to the nose cone. I took a X-acto knife and very carefully put it between the nose cone and chassis (see pic) and pulled up on the body and it popped right off. I have the Carrera version also, but I couldn't pass on this one back when it came out. Being a fan of the winged cars , I find the poor execution being kind of charming/interesting. It looks fine running around the track.
          I had thought of picking another one up back when they were still available and converting it to a regular Charger 500. The wing will pop out. Add the Charger grille and bumper and fill the wing holes up and touch up the paint. They have gotten a bit pricey now. Wouldn't mine trying it though. 😊
          Click image for larger version  Name:	20220114_222917.jpg Views:	0 Size:	3.36 MB ID:	142962
          Click image for larger version  Name:	20220114_223954.jpg Views:	1 Size:	1.55 MB ID:	142966
          • Macphee888
            Macphee888 commented
            Thanks for the visuals. If I had known the car had the nose glued on like that, I wouldn't have bothered buying it. Pretty tough to get body float on this car, without butchering it.
          I've got the #22 even though it's apparently not absolutely correct body but it's one of the quickest cars in our Nascar and stockers grid.
          Bram,
          CHCH NZ
            It would seem that Scalextric has found a way to totally screw up another American car. The tunnel window and hubcaps on the #22 car were colossal dummy moves, but that Bulbous Nose just has to be recalled. That's ridiculous.
              I forgot about the hubcaps, but those gold wheels do look the part on my '55 Chev Nomad wagon.
              Last edited by Wobble; January 15, 2022, 03:50 AM. Reason: photo didn't load properly
              Bram,
              CHCH NZ
              • dge467
                dge467 commented
                Yes ,those wheels ended up on a few projects of mine too. Great looking Nomad by the way.
              Lookin good Bram!!!
              Eric Foster
              Port Republic Va
