After a quick tire and guide upgrade on the Fly GT-40 I did a 30 lap test run, then for comparison cleaned the tires on my C6 NSR. Wow big upset for today the little Fly takes the Fast time of the day! 2.2 for Fly 2.24 for NSR. Huge difference putting some new tires and a better guide on this car.
FLY vs NSR home track solo event.
As a fellow solo racer I appreciate you posting this. My Le Mans series (World Sportscar Championship Series) is composed of mostly Fly classics and they run very well against Scalextric, MRRC, and one Carrera Porsche 917K. I don't have any NSR cars, but there are some Slot.It cars in the Can Am series where a Fly 917/10 has come out on top many times.
Solo events can be fun too. Treat yourself to an NSR sometime, I’ve only got the one but it’s really an amazing car. I’m not sure if it’s the tires, the motor, the chassis, I guess it’s the combination but it just flys effortlessly around my track. They Flys cars I have are tough completion though, they do give the expensive car so thing to work for.
Is the NSR sidewinder or anglewinder?
On my smallish track, I found an anglewinder NSR to be extremely overpowered for the track. A Baby King calmed it down and made it much more driveable.
Same with a sidewinder NSR with the 25,000 Shark. Too much power. I tamed it down with an orange Slot It motor.
Lower powered Flys can excel on a shorter track against higher powered cars.
WB2 Mine is a sidewinder with the 25,000 Shark motor. It’s a handful but fun, faster than anything else I’ve got, but it’s fun to tune up the others and see how they do against the NSR times. The NSR with a few more laps to warm up would do a little better, the Fly is giving me all it’s got for now. I put in a slotting guide and that really made the Fly handle my track better.Last edited by Michael Squier; January 2, 2022, 05:53 PM.
I have 3 NSR cars: two 908 and one 917/10. One 908 was bought complete from NSR while the other 2 are built using NSR parts. All have new chassis. One 908 has a black(med) chassis and a blue (soft) pod, the other 908 has a blue chassis and a black pod The 917/10 has a blue chassis and a black pod. All have tape across chassis and pod. I have a 65 ft routed track that is 99% flat and technical. 917 has 25k predator sw geared 11/32. All are stuck to track with no sliding around corners. It appears that putting tape across chassis and pod works wonders. Without tape all slide around corners a little. Track voltage is 12 volts.
Joseph
Minor update, since this post I have put homemade foam rings in the air wheels center. On my very short track the contact patch of the NSR was just riding on the edges. On most days the NSR is back ahead of the Fly, but not by much. On a long race these two would be very competitive on my track.
FLYs are fun to tune, with so many tweaks to play for weight or gear ratio, depending on class allowances. Great detail in the liveries.
NSRs will always be considered by me to simply be a race-ready car, where we have high expectations for good quality clean racing because they handle so well (and tape the bottom if one needs it) Big fan of the baby king swap too. A car that handles better with a little less rpms, if geared correctly, will be faster than a higher rpm motor that is simply too much for some track designs or voltage.
We don't run FLYs with same motor class as NSR GT (nor against each other of course), but even if we did, I would be stunned if the NSR didn't win most times in a 'for the hell of it' test (unless a Mosler lost once in a while). Very interesting that you got competitive results.
Tony
... Hobbit Racing...
...Tampa, FL, USA...
Hobbit Racing on YouTube @
https://www.facebook.com/hobbitracingpark/
