Hi, just building up 2 x NSR AMG slot cars, any tips please ?. I race on wooden routed tracks
1 - building 25k shark SW with standard chassis. Chassis feels way too flexible, ive strengthened the pod, but not sure if i should strengthen the chassis also ? Was going to use very little weight, maybe just a bit just in front of the motor, will this be enough or will the front wheels pop up ?
2 - ive got a green extra hard chassis and was going to build up a AW to race on a big 8 lane magna braid track. Was thinking slot.it red, blue slotting plus (mag downforce), Scaleauto Sprinter 300gr or the NSR 21 King motor. The NSR 21 King motor I usually find a bit too much motor and basically can only get moslers to run very well but was thinking of maybe trying the AMG. What sort of weight setup for AW AMG please ? I usually brace the rear of my AW
Ive put 4 x NSR grub screws in the chassis holes for the body to rock on. I set them only about 1mm high. Would 17mm fronts be ok to get max width on the front, or will i need to go down to 16mm. Speaking of fronts, ive been applying 2 coats of glue to the front tyres and smoothing. Tyres are rock hard, not sure if this is good or not ? maybe go for some zero grips ? Do you need a bit of flex in the rubber ?
Thank you
Thank you
