Harry Wise stated that either his BrassAm chassis, or his Showdown chassis, (I think it was the BrassAm) could be built as an inline, or sidewinder (or anglewinder, too, I believe). I've built two inlines, that I'm happy with. My question : does anyone know if there is an Instructional Guide, or possibly a video, of how to do a 1/32 "Harry-Chassis", as a SIDEWINDER ?? If I could build a Sidewinder, my bodies wouldn't be limited to Stock Cars and Touring Cars. I could figure out fitting a few Prototype sports cars, and CanAm cars.
A Scratchbuild Question
Building a sidewinder can be made much easier by using a commercially available motor bracket..........the JKC92 / JK25005 bracket is a great bracket to start with ,and it is configured for FC-130 /FK 180 motors to bolt right in. The bracket is soldered to one of your main chassis rails, and the motor is screwed to the bracket.
I believe SCC sells these, as do most commercial raceways.
Here is a pic. of a chassis I built using one of these brackets.......
The finished chassis........
You can always make your life easier, and use an existing plastic sidewinder bracket (Slot-it, Scaleauto etc.) which can be bolted into a brass/wire main plate.....
And this is the JK bracket..............
Originally posted by davidxl9 View PostI'm interested in building a chassis like this. Are there any plans or specs for it?
Originally posted by chrisguyw View Post
Which chassis are you referring to ??............while specific plans for scratchbuilt chassis are generally non existent, if you do have any specific questions, I would be happy to help.
Thank you for the quick reply! I was referring to the chassis in your first picture. I would like to know the thickness of the flat stock, size of wire and tubing. Also, I would like to see some pictures with the wheels off if possible.
Chris,
As far as materials,...if you are making a 1/32 chassis here are some material guidelines. Please be aware that wire and brass thickness can vary depending on the track and motor you plan to use.
The following should be just fine for 90% of what you may build......
Main rails............................................. .................... .055 piano wire
Front axle supports.......................................... ... .047 piano wire
Guide tongue............................................ ............. .063 brass,..........you can find brass/steel guide tongues online.
Side pans/cross braces/body mounts.......... .032 brass
Pan mount wire.............................................. ...... .030 piano wire
Again, this should cover most of your builds. but do not consider them "gospel" if you track is either extremely tight/twisty, or, fast flowing.
Please shout if you need more help
PS If you are serious about scratchbuilding. and plan to do a few chassis, it would be a very good idea to either buy, or make a chassis jig..........tons of chassis have been made on simple homemade jigs 😀
I will add to Chris,s comment about chassis jig. There is no need to rush out and buy a jig, for many years I simply used a block of MDF with some holes drilled for pins, it was easily damaged by the heat of soldering, but easily replaced. I have seen lots of guys buy these great jigs only to find that they just could not come to grips with building chassis.
Originally posted by Mitch58 View PostChris W,
Which brass inline bracket is that?
