My first scratch build was basically Harry's Showdown 1/32 Chassis. Had a couple of problems
, but it ended up turning out well, especially for my first try. Had some learning issues with the second Build, but ended up happy with it, as well.
My third Build is giving me a strange problem, right outta the gate : I can't get the 3/32 axle to go into the 3/32 bushings I bought ! I checked my Order (and even my order previous to that) from Slot Car Corner, and all looked correct. I am obviously missing something. What Size Bushings (inside diameter) Do 3/32 Axles Fit Into, since I figure 3/32 axle can't be pushed into same size hole in a bushing. Seems the hole in the bushing should be slightly larger than the 3/32 ?? I also know, the outside diameter of the bushing must be 3/16, in order to fit inside the 7/32 round brass tube ! I don't know if maybe I was sent the wrong size axles, or what. Can't quite understand, why things fit fine, on my first two Builds, and I'm having this problem, this time. Advise, please !!
