Converting a SlotIt Group C slot car from an inline a sidewinder motor configuration
Tags: None
Well done tutorial on this change. This is my current favorite thing to do with the slot.it Group C cars. I use the newer SW pod made to accept flanged bearings. I use ball bearings just ‘cause I can and I haven’t entered any proxies yet. The body clearance issue showed up in a Porsche 962 with the the spur gear rubbing on the underside of one of the rear deck ducts. A little careful Dremel work easily took care of it. This is a great conversion for someone just getting into serious tinkering .Straightforward and rewarding.Mike V.
Western North Carolina
I am curious why you would do this. Online should have better balance but more friction loss. As I recall from the 60s, sidewinders put more weight on the rear tires.
More weight on the rear tire gives: Better traction, Better cornering speeds, Better braking. But I'm a rookie. I'll let the big boys chime in.
This may help with deciding if a SW configuration is right for you. Check out the cars from the World Championship Proxy Group C builds.
Converting a SlotIt GrC to SW is a no brainer if rules allow, I have a XJR14 with a Shark 22 and it beats most NSR Moslers on our wood track and it's so easy to drive.
...flexy wing mounts would be a good idea, I made a pair from a 1mm thick sheet of black neoprene rubber and superglued them to the wing and rear mountKevan - Isle of Man
Just for fun, I converted a Carrera DTM Audi sedan to an NSR EVO King anglewinder. It really moves now!
The really difference here is with an in-line the pod will flex between the motor and the axle. That small flex will impact handling. If you want to try to experiment with an inline, try adding bracing from the motor to the top of the bushing holder. You will see a significant improvement with the handling.
Thanks for the vid jrrclk and for sharing your conversions above guys. I started my first conversion today. Waiting on a pinion and gear, but did a test fit with parts I have on hand and it's looking good so far. I'm using the stock motor and it has enough axle clearance. I'll need to cut the shaft on the end bell to allow room for the tire.
Edit. The new chassis had plenty of clearance for the spur gear so no need to cut. New pic attached for the test fit.Last edited by code; December 15, 2021, 07:30 PM.Mike
Oz
Hi Mike, You may want to consider reversing the Spur (with the boss on the outside).......this will give you a bit more space between the spur and the tire which will allow you to run the spur fully on the pinion without the pinion rubbing the tire.
Hi Chris, thanks, will do. Some chassis material needs to be slightly removed in that area to accomodate the spur gear with the boss on the outside. I'll do this on a new chassis I'm waiting for, as the one on this car is the original without the front axle adjustment.Last edited by code; December 14, 2021, 01:08 AM.
Love the tutorial, sharing visually is great for newbies!
It's trial and error and personal preferences as to which is 'better', particularly if keeping the motor spec the same. So many ways to slice it is what makes our hobby so much fun!
Some of my best Slot.it cars are Inline, exactly as they came, even after attempting to 'improve' them. GrpC, DTM, GT, all screamers! Learning to change the setup is the best take home message so we all recognize the options. Claiming one is better than the other, I'd beg to differ,,,er, rather race you over it, if given the chanceTony
... Hobbit Racing...
...Tampa, FL, USA...
Hobbit Racing on YouTube @
https://www.facebook.com/hobbitracingpark/
Originally posted by code View PostThanks for the vid jrrclk and for sharing your conversions above guys. I started my first conversion today. Waiting on a pinion and gear, but did a test fit with parts I have on hand and it's looking good so far. I'm using the stock motor and it has enough axle clearance. I'll need to cut the shaft on the end bell to allow room for the tire.
