New front end axle blocks and bushings from MRSlotcar/SCaleRacing.
These bits and pieces will be shipping soon.......................and should be available at SCC, Pendle, 132Slotcar us to name a few.
They are produced by MRSlotcar, and will be packaged/sold under the ScaleRacing banner....
The kit on the left ( SR-2101 ) contains 2 axle uprights, bushings, set screws for adjusting the axle height, and screws for attaching the axle blocks to the chassis. The blocks are drilled on the bottom to accept the supplied screws, (2 holes must be drilled into the chassis plate) or, the blocks can be glued into position. The bushings are inserted into the blocks, and take a lot of the slop out of the front axle assembly. The set screws are used to position the bushings, with the set screws touching the outside flange of the axle, allowing the axle to spin in the precision bushing.
The kit on the right (SR-2102 ) contains 2 bushings which can be used in the front end of several manufacturers cars....Slot-it, NSR, Policar, Scaleauto etc. etc., and they remove a lot of the slop found in some front end set-ups., as well as allowing the axle to spin in the bushings, not against the set screws.
