I've found my first qualm with Carrera. If one buys two 2/30 high banked curve kits there is a general expectation that each will be 180 degrees in total. This is not the case, however, as each kit seems to be short by 5-10 degrees. I'm not sure the exact amount as I don't want to start snapping track. This is silly.
Has anyone here run into and solved this problem already?
Update: I've bent the curve, but should one of these clips fail I could be killed by the shrapnel. Nice knowing y'all, in that case
