I've recently acquired a Professor Motor tire truing machine and have been spending plenty of time going over the tires on my cars. I true the tires until I see no (and I mean not any!) runout as measured with a standard dial indicator.
Now I am wondering if a glued and trued set of tires will go out-of-true as they wear. Should I be touching up my tires before race events? Is this common practice or is it not necessary?
The most likely cause I can see for tires wearing out-of-true would be variations in the rubber's properties around the circumference of the tire. Those might be caused by the molding process -- how the rubber is poured or injection molded. But it might take a significant amount of wear before a tire becomes measurably out-of-true.
I doubt tires would go out-of-true just in storage -- properly stored so there is no weight on them. I could be wrong. It happens.
No, I think practice laps would be the cause. How many? That would be the question. A few dozen? A few hundred? A few thousand? TBD.
