Anyone run this car yet? I received mine last Friday, (2 days, thanks SCC) beauty, but the wing requires assembly, 3 pieces, not an easy task! The holes in bottom of wing were almost nonexistent and the tabs on struts are almost as bad. Took it for some laps and the rear end was bouncing badly. Thought I had a tire not seated (I thought I checked, but I am old). No, tires were fine. Glued tires to rims after filling “air gaps”. Noticed a large amount of play on the axle, similar to knurled axle cars? Replaced bushings and axle, but still had bounce under hard acceleration. Put some motor pod screws in the back of pod, for a total of 6. That cured the bounce. The tires are very sticky and we’re difficult to true, wanted to “chunk “. Not sure what brand of tires. Now runs pretty good, but all in all, not a good experience for a $70+ car.
Harry
Harry
