so i got a new hudy from SCC yesterday. the manual says to clean it after use,but makes no mention of lubrication points or type. are the bearings sealed for no maintenance? been looking around but cant seem to find ant info, maybe im looking in the wrong area.looks like a nice machine and i'd hate to wreck it. any info on maintenance would be appretiated. thanks,bill
hudy maintenance
If its new it won't need oiling for ages, I don't think I've oiled mine more than twice since I got it 4 years ago. Light bearing oil on the moving parts just like your slot cars.
Brush & vacuum will be needed.Kevan - Isle of Man
You shouldn't have to worry about lubricating the bearing on a new Hudy tire truer. Keep it clean with bottled air (Blow Off or equivalent) after each use; get a sanding belt cleaner like Butch suggested and it should last a long, long time. You really want to keep the sanding drum as clean as you can; particularly if you're truing either silicone or soft rubber (NSR Ultragrips or equivalent) tires.
One other thing that you'll want to do on the penultimate grind (the next to the last one) is to move the mandrel inward and back by pushing against the back of the mandrel. This gets, or helps to get, rid of any lines that appear in your tires as you true them.
You will really like this tire truer!
Excellent. Thanks Guys for the info I do know about that big eraser, what about that part about lining up the drum with the spindle, is that necessary on a brand new machine?bill ,framingham ma
I'll be interested to see what you get for replies to this question, since the instructions that come with the Hudy say to be sure that the mandrel and the drum are aligned before starting to true tires. But, I have never seen a description of exactly how to do that. It is, however, a critical part of truing a fast tire.
our club uses silicon and a member has been truing his tires with a hudy for years so i figured i'd try one. ran it last night and seemed to work well.bill ,framingham ma
