Making hay bales, I started by making some bales out of modeling clay. They measured a scale 18" x 18" x 36" . I used the clay shown, but to be honest, I didn't like it taht much because of the texture. In any case, I used it anyway because it was what I had on hand.
I added detail using a wire brush and a small piece of 22 gauge wire (to emboss teh baling twine). It was hard making them all the same size, but I figure I'll use the good ones up front & on top & the lumpy crappy ones in the back & on the bottom of the stacks.
Next, using the clay master patterns of hay bales I made, I made a silicone rubber mold. Now I can cast 1000 bales if I want to, and won't have to sculpt every single one.
OK, so I cast some hydrocal plaster bales.
When dry, I spray painted them flat tan.
When that was dry I gave them a burnt umber wash.
When that was dry I gave them a dry brushing with a very light flat tan.
Finally, I rubbed some glue on them & rolled them in some sawdust. It wasn't important that every single bit of the bales got covered, but just enough to add some texture.
This was my first attempt at making these & I'm pretty happy with the way most of them turned out. Now, I only have to make about 500 more.
Any questions?
Any questions?
