Here is a video I did on how I setup my 1/32 scale Thunderslot Lola T70 CanAm for the NorCal slot car circuit
How I setup my 1/32 scale Thunderslot Lola T70 CanAm for the NorCal slot car circuit
Tags: None
Originally posted by r377 View Postkeep up with the updates please. I always found the stock chassis and pod too soft but not upgraded yet.
What difference between the hard pod and the stiff pod ?
I usually pod a little bit of lead up near the guide to keep the front end down
There are so many ways to skin a cat with Thunderslots. I’m a extra hard pod with a medium chassis on 2 of my Lolas and my only Mclaren.Last edited by Brumos RSR; July 7, 2021, 08:58 AM.The Jester
the Soxside (Chicago)
Interesting to see different ways of setting up these extremely fast, light and fun cars. Crazy for me to see even higher rpm motor being run.
Worked on mine with Scott on 2nd set up, as it seemed it could get faster. Everything stock and silicon tires for us, the TS/Mabuchi motor rips, except this time almost entire motor pod filled with 0.016" lead to keep it steady and pinned down. Gained nearly a tenth and I'm happy to say if you check the CanAm results last time @WER, a certain #11 McLaren reached the top of the podium!Tony
... Hobbit Racing...
...Tampa, FL, USA...
Hobbit Racing on YouTube @
Jim how did your next build go with the harder chassis ?
Also, i prefer the regular body and motor mount screws to the standard t.s. what would you recommend thanks ?
